Agelakuter Posted February 27, 2009 Share Posted February 27, 2009 Some of my files can't be defragged.... Can anyone help? Thanks Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted February 27, 2009 Moderators Share Posted February 27, 2009 You are going to have to give more info than that when you post a problem/query on any forum. Operating system used e.g xp or vista Which version of the 'problem' software are you using What error messge, if any, did you get. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
kmillerusaf Posted February 27, 2009 Share Posted February 27, 2009 You are going to have to give more info than that when you post a problem/query on any forum. Operating system used e.g xp or vista Which version of the 'problem' software are you using What error messge, if any, did you get. Add to that, what files are you not able to defrag? If they are currently being used by the system (such as $MFT or pagefile.sys), you will not be able to defrag them. Keith There's always an exception to the rule. I'm that exception. Desktop ----- AMD Athlon 3700+ (2.64Ghz), 2GB DDR 400, ASUS A8N-SLI Premium, 500GB HD, Windows XP Pro SP3, Avira Antivir Personal At work ----- Intel C2D T1700 (1.6Ghz), 2GB DDR2 667, Dell OUY141, 80GB HD, Windows XP Pro SP2, Symantec 10 Laptop ----- Intel C2D P8400 (2.4 Ghz), 4GB DDR3 1066, Mainboard, 160GB HD, Dualboot: Windows 7/openSUSE 11.1, Avira Antivir Personal Link to comment Share on other sites More sharing options...
