Winapp2.ini Posted June 19, 2008 Share Posted June 19, 2008 removed winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Talldog9 Posted June 20, 2008 Share Posted June 20, 2008 I'm sure the problem is a registry entry for the recycle bin but have no clue which one. Maybe there is a program out there that can replace the recycle bin if you need the functionality. The internet - Where men are men, women are men and children are FBI agents. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 20, 2008 Author Share Posted June 20, 2008 mrr. I don't need it, persay. But I do like to keep things in there until I delete them, sometimes I mistakenly delete files I want (I had to remove a rootkit once, and almost deleted my realtek audio driver :x) and this would cause major problems. I'll look into a program to fix this though. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 20, 2008 Moderators Share Posted June 20, 2008 http://support.microsoft.com/kb/810869 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 20, 2008 Author Share Posted June 20, 2008 Edit: Problem Solved, I had to Shift-Delete the C:\RECYCLER directory so windows could re-write the corrupted info files. Thank you for helping me . winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
