abu aufa Posted March 25, 2008 Share Posted March 25, 2008 Hi all, I run CCleaner this morning and I found 218 registry issues in registry integrity section. Is is safe to delete all issues without back up the registry ? Thank for your suggestions wishes, Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 25, 2008 Moderators Share Posted March 25, 2008 Hello abu A read here may give you some tips. http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/ A brief explaination is when you do an issues scan and choose to fix, you are offered the choice of saving those entries. They are saved by default in my documents, look like a piece of paper with blue blocks on and be called someting like cc_ 20080425.reg (todays date). If you had problems after removing the entries just right click on the backup and choose merge. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
doubleduce803 Posted April 21, 2008 Share Posted April 21, 2008 cant use ADOBE READER 8 LINK WAS LOST AFTER USEING CC CLEANER Hello abu A read here may give you some tips. http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/ A brief explaination is when you do an issues scan and choose to fix, you are offered the choice of saving those entries. They are saved by default in my documents, look like a piece of paper with blue blocks on and be called someting like cc_ 20080425.reg (todays date). If you had problems after removing the entries just right click on the backup and choose merge. Link to comment Share on other sites More sharing options...
doubleduce803 Posted April 21, 2008 Share Posted April 21, 2008 HOW DO U RESTORE LOST DATA, THAT WAS REMOVE IN CC CLEANER? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 21, 2008 Moderators Share Posted April 21, 2008 Did you lose it after an issues scan? Have you tried system restore? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
