Whiteshark Posted May 13, 2007 Share Posted May 13, 2007 Currently this is the only "bug" i can report. Since i can't find any other user reporting the same issue, i guess this is a fault of my S.O. Windows XP Pro sp2 fully patched. IE7 ver. 7.0.5730.11 CCleaner detect and clean everything as always, but index.dat files Note: I can easily delete them using another application (after reboot, of course). Note2: Tried previous versions of CCleaner (included the portable one). No way Any help will be appreciated Guide in italiano per CCleaner - Recuva - Defraggler - Speccy Link to comment Share on other sites More sharing options...
MajoMo Posted May 13, 2007 Share Posted May 13, 2007 Same to me. Win 2000 Pro Analyse process found one index.dat file only - but can't remove it. After rebooting the file is the same (size and the content). Can't find the others index.dat'files. With another app. like MV AntiSpy and Index.dat Suite all the index.dat files are found and deleted. The source'problem can't to be about OS and/or language OS. Link to comment Share on other sites More sharing options...
Whiteshark Posted May 13, 2007 Author Share Posted May 13, 2007 Same to me. Win 2000 Pro Analyse process found one index.dat file only - but can't remove it. After rebooting the file is the same (size and the content). Can't find the others index.dat'files. With another app. like MV AntiSpy and Index.dat Suite all the index.dat files are found and deleted. The source'problem can't to be about OS and/or language OS. Well, making a file search (unhiding all file types, of course) i can find 6 or 7 index.dat files, in Application Data, Local Settings and System paths. They are all 16 or 32 KB, are unlocked by the system, and are deletable simply using right click > delete. The... "good one" is in G:/Temporary Internet Files/Content.IE5 folder, and currently is about 500Kb or so. CCleaner Analyze doesn't detect any index.dat file at all, here. Guide in italiano per CCleaner - Recuva - Defraggler - Speccy Link to comment Share on other sites More sharing options...
JDPower Posted May 13, 2007 Share Posted May 13, 2007 A quick search of all files on my system (XP Home) finds 8 index.dat files, none above 76Kb The... "good one" is in G:/Temporary Internet Files/Content.IE5 folder, and currently is about 500Kb or so. My Content.IE5 folder is at: C:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5 And the index.dat there is 32Kb Link to comment Share on other sites More sharing options...
Whiteshark Posted May 18, 2007 Author Share Posted May 18, 2007 A quick search of all files on my system (XP Home) finds 8 index.dat files, none above 76Kb My Content.IE5 folder is at: C:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5 And the index.dat there is 32Kb Wonder that is a "systemprofile" not in use, since i can delete the index.dat file in that path without reboot. I know my Internet Cache is not keeped in the default location (it is moved in G:\Temporary Internet Files\), but is my choice and is like this from ages, and has never been a problem for CCleaner. It find and clean all the other files type in that location (temporary internet, cookies, history, and so on...) but not index.dat ones. Neither after the latest update to 1.40.520. Guide in italiano per CCleaner - Recuva - Defraggler - Speccy Link to comment Share on other sites More sharing options...
