slm1997 Posted April 10, 2007 Share Posted April 10, 2007 When I turn on my computer, I get the following error message: RTHDCPL.EXE - Illegal system DLL relocation The system DLL user32.DLL was relocated in memory. The application will not run properly. The relocation occurred because the DLL c:\windows\system32\hhctrl.ocx occupied an address range reserved for windows system DLL's. The vendor supplying the DLL should be contacted for a new DLL. I don't have a clue what this means, how it got in my computer, or how to delete this error message from coming up everytime my computer is booted up. My system works fine, but the message and how it got there is annoying. If anyone can help me, please advise. Thank you! SLM1997 Link to comment Share on other sites More sharing options...
Moderators rridgely Posted April 10, 2007 Moderators Share Posted April 10, 2007 Hi, Its the intel sound manager thing.(the orange icon in your system tray) I had this happen to me on my laptop a couple of weeks ago. I deleted its start up key with hijackthis and the problem was fixed. If you want to post a log I'll show you which entry to fix. Link to comment Share on other sites More sharing options...
TheOdds Posted April 10, 2007 Share Posted April 10, 2007 This problem may occur after you install security update 925902 (MS07-017) and security update 928843 (MS07-008). The Hhctrl.ocx file that is included in security update 928843 and the User32.dll file that is included in security update 925902 have conflicting base addresses. This problem occurs if the program loads the Hhctrl.ocx file before it loads the User32.dll file. http://support.microsoft.com/default.aspx/kb/935448/en-us A patch for this is most likely also included in todays Windows updates. Link to comment Share on other sites More sharing options...
Moderators rridgely Posted April 10, 2007 Moderators Share Posted April 10, 2007 http://support.microsoft.com/default.aspx/kb/935448/en-us A patch for this is most likely also included in todays Windows updates. Thanks for posting that. I noticed the issue when I reformatted my laptop a couple weeks ago and then ran windows update. That program doesn't really do anything all that usefull so I wasn't too annoyed, but its good to know that they fixed it. Link to comment Share on other sites More sharing options...
acooldozen Posted April 11, 2007 Share Posted April 11, 2007 Thanks for posting that. I noticed the issue when I reformatted my laptop a couple weeks ago and then ran windows update. That program doesn't really do anything all that usefull so I wasn't too annoyed, but its good to know that they fixed it. This error occured because of Microsoft security update KB925902 On April 3/07. No need for the Hotfix Patch if you update Realtech soundcard. see: http://www.dozleng.com/updates/index.php?s...13838&st=10 ..........and Make yourself a Great Day! Cheers, Lyle Keep your software up to date http://www.dozleng.com/updates/index.php? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 12, 2007 Moderators Share Posted April 12, 2007 TugZip had the same problem, thus the recently released updated version of it with no new features but instead just to fix the "Microsoft induced problem." The effected items are: ? Realtek HD Audio Control Panel ? ElsterFormular 2006/2007 ? TUGZip ? CD-Tag Link to comment Share on other sites More sharing options...
