jaqLs Posted October 14, 2006 Share Posted October 14, 2006 I've actually used this program for a long time and just now discovered the help forums. The thing is after I use CCleaner I have to uninstall it because if I leave it in my PC I always get an error message during windows startup. Something about memory and that I have to press F2 to load default values. Then if I load the default values windows loads up fine then I just have to change the date and time (because it will show an old date and the wrong time). So whenever I use CCleaner I install it and then uninstall it again until I have to clean my PC. Is this a known CCleaner bug? Link to comment Share on other sites More sharing options...
Eldmannen Posted October 14, 2006 Share Posted October 14, 2006 Sounds very strange... Link to comment Share on other sites More sharing options...
jaqLs Posted October 15, 2006 Author Share Posted October 15, 2006 Yeah it was strange at first but I kinda got used to it. I just wanted to be able use CCleaner regularly. So anyway, does anyone have the same problem? I'm using win98 with a busted video card (although I don't think there's a connection). Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted October 20, 2006 Share Posted October 20, 2006 welcome to the forums its not a known issue. try booting up into safe mode. i dont think it was ccleaner but rather another program in your startup that "stole" all of the memory. o ya, to get to safe mode, keep pressing F8. im pretty sure thats what it is for W98 Link to comment Share on other sites More sharing options...
