horserider Posted September 6, 2006 Share Posted September 6, 2006 Hi, Am a beginner. Did successfully download CCleaner. Went through my first analysis but nothing appeared on the board. A complete white page although I did see an active analysis process going on. Did follow proper instructions as to set the program up. Hesitate before going on with the clean-up process for I don't know what goes on. Any suggestions? Thanx Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted September 6, 2006 Share Posted September 6, 2006 hi there. have you had a look here, http://forum.ccleaner.com/index.php?showto...92&hl=tarun Link to comment Share on other sites More sharing options...
horserider Posted September 7, 2006 Author Share Posted September 7, 2006 hi there. have you had a look here, http://forum.ccleaner.com/index.php?showto...92&hl=tarun Hi, thanks for answering. I did take a look at the link. Wonder whether this new download - Visual Basic 6 Runtimes - would fix my problem with CCleaner. My computer is only a Pentium II (266mHz) working with Windows 98se... Does it make a difference? Wait for your reply. Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted September 8, 2006 Share Posted September 8, 2006 firstly, you can try running it in safe mode and see if that works. if not, you can go HERE to download VB. (same link as in taruns post) Supported Operating Systems: Windows 2000; Windows 2000 Advanced Server; Windows 2000 Server; Windows 2000 Service Pack 2; Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows 95; Windows 98; Windows 98 Second Edition; Windows ME; Windows NT; Windows Server 2003; Windows XP Link to comment Share on other sites More sharing options...
horserider Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks for answering, guys. I will follow your suggestion. Kind of amazing, though, that I have to download this program after using the same computer for more than one year without having the problems I have now. Thanx a bunch again ! Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted September 12, 2006 Share Posted September 12, 2006 Went through my first analysis but nothing appeared on the board. this program is using VB. you may not have had to use it for anything else if you dont do much on your PC. MrG is working on programming it in a different language so i dont think you will need VB when this new version comes out. dont quote me on that, i could be wrong. Link to comment Share on other sites More sharing options...
