MarkA70 Posted March 2 Share Posted March 2 Paid for and received the CCleaner for Mac upgrade. Installed upgrade, Copy and Pasted the License Key from the email. Get the message that key is registered. What the heck? How to fix this??? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 2 Moderators Share Posted March 2 Did you get the license from ccleaner.com? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Thiago Mendes Posted March 12 Share Posted March 12 I have the same problem, I bought it and the key that arrived is not valid. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 13 Moderators Share Posted March 13 As i asked above did you get it from ccleaner.com 3 hours ago, Thiago Mendes said: I have the same problem, I bought it and the key that arrived is not valid. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Guest Andrei CCleaner Posted March 13 Share Posted March 13 @Thiago Mendes @MarkA70 please email our team at support@ccleaner.com so they could check your license key and help you out. Link to comment Share on other sites More sharing options...
