Paul Uchiha Posted October 14, 2022 Share Posted October 14, 2022 It's been over a week now that private connection is not working in my laptop? Any ideas in how to solve this issue? Link to comment Share on other sites More sharing options...
SeanT Posted October 16, 2022 Share Posted October 16, 2022 Hi Paul wish I did! I'm getting the same message for the past 2 days as well. WHERE IS PIRIFORM'S KAMO SUPPORT STAFF WHEN YOU NEED THEM? Link to comment Share on other sites More sharing options...
marcobras Posted October 17, 2022 Share Posted October 17, 2022 i have the same problem, when CCLEANER resolve this ? We pay for thar service. Marc Link to comment Share on other sites More sharing options...
Paul Uchiha Posted October 18, 2022 Author Share Posted October 18, 2022 (edited) I tried a complete uninstall, cleaning the registry, eliminating residual archives, none of that work, what seems to do the trick was a 'Repair'. However I cannot choose a specific location for the private connection. Edited October 18, 2022 by Paul Uchiha Link to comment Share on other sites More sharing options...
Featured Comment Guest Andrei CCleaner Posted October 18, 2022 Featured Comment Share Posted October 18, 2022 Heya @SeanT @Paul Uchiha and @marcobras please email our team at support@ccleaner.com so they could have a closer look over your Kamo situation. Link to comment Share on other sites More sharing options...
Pugsie Posted November 14 Share Posted November 14 Was there a fix for this? I have the same problem. Link to comment Share on other sites More sharing options...
Raptor Posted November 21 Share Posted November 21 (edited) Het ondersteuningsteam moet dan wel reageren. En dat gaat maar erg traag of beter gezegd helemaal niet! Edited November 21 by Raptor Link to comment Share on other sites More sharing options...
Raptor Posted November 22 Share Posted November 22 (edited) Op 14-11-2023 om 04:29 zei Pugsie: Was hier een oplossing voor? Ik heb hetzelfde probleem. Ik zou bijna zeggen als je betaalde versie is afgelopen , geen nieuwe meer aan te gaan. Wat een slechte service van cccleaner / piriform. Geen enkele mededeling van informatie op hun site te vinden en dat het al ruim een week duurt en nog steeds niet werkt vind ik enorm teleurstellend. Het lijkt wel het kabinet Rutte, wel betalen, maar geen oplossing bieden. Edited November 22 by Raptor woorden niet juist Link to comment Share on other sites More sharing options...
Raptor Posted November 24 Share Posted November 24 (edited) On 22/11/2023 at 04:39, Raptor said: Ondersteuning heeft contact opgenomen en opnieuw geïnstalleerd aan geraden. Tijdens de opdracht om Kamo te verwijderen werd gevraagd of je het wilde verwijderen of herstellen. Ik heb de herstellen functie gebruikt en Kamo werkt weer. Daarvoor had ik al eens geprobeerd om het helemaal opnieuw te installeren dat werkte niet. Probeer dus eerst de herstel functie. Moderator translation by google Support contacted and recommended reinstallation. During the command to uninstall Kamo, you were asked whether you wanted to uninstall or restore it. I used the restore function and Kamo is working again. Before that I had already tried to install it from scratch, but that didn't work. So try the recovery function first. Edited November 24 by Nergal verdraaien van woorden Link to comment Share on other sites More sharing options...
Posted by Guest Andrei CCleaner,
0 reactions
Go to this post
