Linda Buzbee Posted April 22, 2022 Share Posted April 22, 2022 When I run Analyze on my CCleaner Professional it NEVER lists System - Empty Recycle Bin, but when I Run the Cleaner it ALWAYS lists System - Empty Recycle Bin 102,701 KB 60 files under the Advanced Report. It always has the same amount of KBs and 60 files whether it is 10 minutes or 3 hours. What does this mean? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 22, 2022 Moderators Share Posted April 22, 2022 (edited) You have a corrupt recycle bin follow the steps in the above post (replacing c: for the letter of the drive containing the ghost files as needed) Edited April 22, 2022 by Nergal Added explanation ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
