ajrfman Posted February 23, 2020 Share Posted February 23, 2020 When I use Cleaner, how can I prevent it from deleting anything concerning WhatsApp? I can reconnect to WhatsApp on my phone until I run CC Cleaner. After using it, I have to rescan WhatsApp, using my cell phone.Usually I have to delete WhatsApp, and download it again in order for the scan to work. It only has this problem after I use CC Cleaner. How can I protect my WhatsApp connectivity files? Link to comment Share on other sites More sharing options...
Moderators nukecad Posted February 23, 2020 Moderators Share Posted February 23, 2020 As you say this is with your phone then I assume that this is CCleaner for Android. Whilst you can make apps and selected cookies 'exceptions' in the regular CCleaner, so that they dont get deleted, unfortunately this 'excluding' is not available in the Android version. The Android version of CCleaner is a bit like the 'EasyClean/Healthcheck' option on the PC - in that it cleans what it does and you have little/no control over just what it clears. (And yes, CCleaner android does clear WhatsApp files). So if it's clearing things that you don't want cleared there is currently only one answer, don't use it. PS. I've moved this into the Android sub-forum. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
