brian_23 Posted December 31, 2018 Share Posted December 31, 2018 The last thing I did was download Defraggler. I had a very old ver.. Well, the last thing I did was run Defraggler. Went to bed. Got up and I have Chrome on my box. I am getting older and its true after 60 stuff starts getting fuzzy sometimes. But not so bad that I get up in the middle of the night and down load APP's load them and then forget it. Did I miss something in the install and not un-tick a box that said I could have Chrome? I am not accusing, but asking if Chrome comes hidden or with Defraggler? Thanks Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 1, 2019 Moderators Share Posted January 1, 2019 (edited) There's is a checkbox at the begining of the install process, however you are not the first to not notice it (it may not have shown but i've seen no proof it wasn't there in other cases) Edited January 1, 2019 by Nergal ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
