dlinc7581 Posted August 15, 2018 Share Posted August 15, 2018 I am new to CC, I just bought it and I thought it cleaned corruption in the registry. I keep getting for instance acroRd32.exe is corrupt, I have tried command prompt things but nothing is working and someone said, shouldn't CC find that in the registry? So here I am asking, if someone could get me in the right direction I would be so appreciative....lost in corrupt world.. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 16, 2018 Moderators Share Posted August 16, 2018 Ccleaner doesn't fix corruption, it seeks out registry items that don't seem to be connected to live programs. Like any registry 'fixer' you shouldn't use it unless you know what you're removing. Read the advice in my signature below. I've moved this thread to the ccleaner discussion board. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators mta Posted August 16, 2018 Moderators Share Posted August 16, 2018 is it just Acrobat Reader that is corrupted, or others? if just the one, uninstall and reinstall the software. if others, it may be a sign of deeper issues (gremlins, hard drive failure) and you should be backing up, scanning your drive, perhaps even a repair reload of Windows. to get you started, start an elevated command prompt and do these; chkdsk c: /r sfc /scannow Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
