CCleaner Community Forums
Temperature for Ryzen 7 2700X reading hot.
unixwizzard
 Share
I recently upgraded to the AMD R7 2700X CPU and it seems that Speccy Pro 1.32.740 is reading the CPU temp at 60C higher.
Confirmed this against AMD Ryzen Master, Core Temp 1.12.1, and HWInfo, all three show the CPU temp running 60C lower.
This is a new Windows 10 install, ver 1803, with all updates/drivers applied. I just noticed the program is reporting the CPU as Summit Ridge when it's a Pinnacle Ridge chip.
Here's a comparison:
5b1c830d793be_2018-06-0921_44_29-Window.thumb.png.bf0adb715408479b81e0632cd426fc74.png
Not sure if it will help, I've attached a Register dump from Core Temp.
CoreTemp-Dump.txt
Link to comment
  • Moderators
sadly, it's a long standing problem of Speccy - reporting wrong temperatures.
it has been brought to the attention of the Admin team.
Backup now & backup often.
It's your digital life - protect it with a backup.
Three things are certain; Birth, Death and loss of data. You control the last.
Link to comment
  • 7 months later...
My apologies for replying to an old topic but has this ever been resolved? I've relied on Speccy for many years for my temperatures but it's recently been reporting 55C+ when idle on my CPU and this concerned me.
I noticed that some tech YouTubers use HWMonitor PRO so I downloaded HWMonitor (not the PRO) and I can confirm that the GPU and Storage devices report the correct temperatures but the CPU isn't quite right.
Speccy at the current moment is reporting a very consistent 57C on all 8 cores of my Ryzen 7 1800x CPU but HWMonitor is reporting a 37 to 46.
Link to comment
  • Moderators
resolved? - nope.
what was a long standing 2'ish year old issue back in June is now a 2.5'ish year old issue.
Link to comment
  • 2 months later...
  • 2 months later...
  • 4 weeks later...
@mta
I bought a Ryzen 2700x today and installed it. I panicked when I saw the temperature readings on the first boot until checking the temp with the bios and  then CoreTemp. (note: beware of bundled apps when installing CoreTemp)
However, I figured out the issue. It's displaying the correct number of degrees, but it's displaying C when it should be F.
Run Speccy and CoreTemp side by side but in the CoreTemp settings check "Display temperatures in Fahrenheit". You'll see the numbers are the same even if the unit of measurement is grossly incorrect.
Link to comment
  • Moderators
that would have scared ya!
Link to comment
  • 3 months later...
I have the same issue, new ryzen 2700x build, properly applied thermal paste (more than enough), high end cpu air cooler (Dark Rock Pro 4) and I get 90-120 C  while in Msi Bios it says 32-38 C. I also had the same problem with my older cpu (A8 6600k) and also the vram of my Gtx 1060 6gb is shown as 2048mbs. I hope they fix this problems.
Link to comment
  • 4 weeks later...
  • 1 month later...
The exact same thing has happened to me on my new system, I was selling my graphics card, the guy asked me to install speccy so he could check that it was the right on and I was shocked to see my cpu readings at 105c after finishing an r6 siege benchmark so I opened core temp to check and that reported a max of 59c.
Link to comment
  • 3 months later...
Its NOT Fahrenheit. When i get a true temp of 43C Speccy shows 107C degrees and after switching to Fahrenheit i get something like 226F (Ryzen 7 2700X).
I had a similar Problem on my AMD A8 6600K before. I would bet this affects only AMD and Intel is paying for it as usual. Intel style marketing.
Edited by SAD
Link to comment
  • 4 weeks later...
On 29/11/2019 at 18:27, Joe Pluta said:
Speccy is showing Fahrenheit temperatures, but identifying them as Celsius.  40°C is 104°F.  I recommend Coretemp, it uses the sensors inside each core.
My reading is 91C and if I change to Fahrenheit it reads 196F so it's not that the wrong scale is used.
Speccy is apparently a bit crappy on the CPU temperature reading. All other temperature readings are ok.
In my BIOS it reads about 40C.
Seems to be a combo of Speccy and the Ryzen 7 2700X ??
Link to comment
  • 4 weeks later...
Looks like this issue still hasn't been solved. AMD Ryzen 7 2700x here as is the case with many of those here. It's a little difficult to believe that every other piece of monitoring software I've tried gets a CPU temp value that is at least very close to what the BIOS shows but the developers of this piece of software can't fix the problem after roughly four years.
Link to comment
For me with a ryzen 5 2600x Speccy is showing 97 deg C when bios is nearer 35/6 deg C. If you convert the speccy number to celcius you get the corect value, so speccy is definitley showing farenhiet temps with celcius units, however when changing speccy to farenheit units temperatures rise accordingly, suggesting speccy is reading farenheit as celcius and then "converting" that to farenheight if you ask speccy to chnage units.
Link to comment
Register a new account
Sign in
 Share
Important Information
