Loman99 0 Posted January 10, 2017 Share Posted January 10, 2017 Hi, i'm new here and hello. Please help. Win7 show a WayTech UPSmatDB9 under devices for my CPS 1400VA UPS, problem is that the software cannot see the ups.I've installed Winpower, UPS tools and CPS Powermeter but no communication between them and UPS. I'm using a usb printer cable to connect UPS to PC, win7 see ups but software don't.Another thing is when i disconnect the 220v, the pc keeps running on the batteries but my monitor shuts down (black screen) Link to post Share on other sites
Moderators mta 0 Posted January 10, 2017 Moderators Share Posted January 10, 2017 did the advice from here; http://www.tomshardware.com/answers/id-3298270/win-ups-software.html not help? Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to post Share on other sites
Moderators Nergal 0 Posted January 11, 2017 Moderators Share Posted January 11, 2017 Is the software for windows 7. iirc win7 used battery settings in power, when a ups is detected. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Loman99 0 Posted January 11, 2017 Author Share Posted January 11, 2017 did the advice from here; http://www.tomshardware.com/answers/id-3298270/win-ups-software.html not help? Yes regarding the monitor, it was on the wrong port. Software is still a problem. Link to post Share on other sites
Loman99 0 Posted January 11, 2017 Author Share Posted January 11, 2017 Is the software for windows 7. iirc win7 used battery settings in power, when a ups is detected. I've checked W7 power settings, but no ups option there. Thx. Link to post Share on other sites
