Mike Rochip Posted April 8, 2006 Share Posted April 8, 2006 Lately when I click on the blue link for more information from MS on an event that is listed the Help and Support window opens but it doesn't connect to MS and there is no info in the box where you type in the terms or link to search for. This may have started when I installed IE7 Beta. However, it is IE6 that opens, not IE7. The Help and Support Service is enabled and running in services.msc. Anyone have any ideas or suggestions? Thanks ! Link to comment Share on other sites More sharing options...
krit86lr Posted April 8, 2006 Share Posted April 8, 2006 Why don't you just revert to IE6? IE7 beta sucks~ (too many bugs) Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
Mike Rochip Posted April 9, 2006 Author Share Posted April 9, 2006 Why don't you just revert to IE6? IE7 beta sucks~ (too many bugs) Because I used the Hotfix cleaner and I'm too lazy to remove IE7 the long way ! Seriously, though I should probably give that a try. Thanks ! Link to comment Share on other sites More sharing options...
JohnDemolition Posted April 9, 2006 Share Posted April 9, 2006 there is a reason why it's called a beta and not a final. as for your problem, ask M$ somehow Link to comment Share on other sites More sharing options...
