ChrisB Posted April 4, 2006 Share Posted April 4, 2006 Hi, when I use ccleaner with the /AUTO switch, it doesn't fix the registry issues! Is it something I'm doing wrong or it's normal behavior? If it's normal behavior, maybe it would be good to create another switch to allow the registry to be fixed when using /AUTO. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 4, 2006 Moderators Share Posted April 4, 2006 /AUTO only tells CCleaner to run the 'Cleaner' which removes junk files. Registry cleaning via 'Issues' must be done manually for obvious safety reasons being that it's important to know what is being removed from the registry. Link to comment Share on other sites More sharing options...
