CCleaner Community Forums
A couple of days ago I made in Project 2010 large project. Since yesterday, the computer began to hang, it rebooted. Today I have decided to check out the project and when the file has been opened - Project file does not recognize this format.
Tell me, who are faced with what can be done?
Link to post
  • Moderators
even though this sounds like a setup spam message, I'll give it the benefit of the doubt.
what is the project filename, complete with extension?
Windows version?
did the computer hang while the project was opened?
worst case, since the project sounds like it's only a few days old, you may simply have to start from scratch.
sounds like you may also need to investigate the computer hanging; maybe overheating, malware etc.
Backup now & backup often.
It's your digital life - protect it with a backup.
Three things are certain; Birth, Death and loss of data. You control the last.
Link to post
  • 2 weeks later...
  • Moderators
Longest step-up spam EVER!
Link to post
Guest
This topic is now closed to further replies.
