george t Posted May 15, 2016 Share Posted May 15, 2016 i am a first time user and am stuck. the program scans and show that x# of files have be found but none of them match the fllters" how do i get at the files? what are the filters so that i can reset them? thanks- george t Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 15, 2016 Moderators Share Posted May 15, 2016 Does this help? http://www.piriform.com/docs/recuva/using-recuva/advanced-mode/specifying-what-to-search-for Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
lauraaa Posted May 26, 2016 Share Posted May 26, 2016 Hello, I'm having a similar issue. I'm trying to recover files from a SD card and during the scan it says that 611 files have been found but after none are listed. I'm not sure what I'm doing wrong? I've tried changing the filters but still can't seem to see the found files Link to comment Share on other sites More sharing options...
Moderators Augeas Posted May 26, 2016 Moderators Share Posted May 26, 2016 The total number of files found includes all files, live and deleted. If you remove any filters then all deleted files will be shown. Link to comment Share on other sites More sharing options...
lauraaa Posted May 27, 2016 Share Posted May 27, 2016 Ah ok, on second look it is finding 611 files but ignoring all of them. Does this mean they are unrecoverable? I've tried ticking all the boxes to show zero size files etc . Thanks for your help. Link to comment Share on other sites More sharing options...
Moderators Augeas Posted May 27, 2016 Moderators Share Posted May 27, 2016 Check Scan for non-deleted files, you should then see everything. Link to comment Share on other sites More sharing options...
