terico Posted October 9, 2015 Share Posted October 9, 2015 Hello, New PC running Win 8.1. Transferred apps and files from old to new PC. I've used CCleaner for years. No issues. With new PC I have latest CCleaner version downloaded from Piriform. CCleaner progresses to 21% then gets stuck for hours cleaning the Systems Empty Recycle Bin folder. If I de-select that folder it runs and cleans fine and finishes quickly. , But if I have System selected, it gets stuck unusually (3 hrs) too long stuck on that folder. Should I leave CC running overnight? Any suggestions, please? Thanks. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 9, 2015 Moderators Share Posted October 9, 2015 Sounds like you may have a corrupt recycle bin. Please see here http://forum.piriform.com/index.php?showtopic=42673 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
terico Posted October 9, 2015 Author Share Posted October 9, 2015 Wonder if to upgrade to Win10 (which is prompting me to do) ad that will clear the issue? Thanks hazelnut for your response. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 9, 2015 Moderators Share Posted October 9, 2015 Fix the corrupt recycle bin before you think about doing an upgrade. No sense in taking corruption with you. Don't worry about doing the corrupt recycle bin fix, just follow the steps and it will work. Plenty of others have done it (which is why we have the fix as a pinned item to point people to.) Remember you don't have to upgrade to Win 10 if you don't want to. Don't be forced into it, it is your machine after all Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
terico Posted October 9, 2015 Author Share Posted October 9, 2015 Agree! Frankly, not crazy about upgrading to Win10. I upgraded my other laptop to Win10, and Chrome is now very unstable. Will follow steps you suggested. Thanks again. Link to comment Share on other sites More sharing options...
ident Posted October 9, 2015 Share Posted October 9, 2015 More probable is filesystem corruption. Have you run chkdsk? No fate but what we make Link to comment Share on other sites More sharing options...
terico Posted October 10, 2015 Author Share Posted October 10, 2015 Hazelnut: Followed the steps you provided above this string to remove the corrupted recycle bin folder. It worked. CCleaner is now running great! Thanks. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 10, 2015 Moderators Share Posted October 10, 2015 Hazelnut: Followed the steps you provided above this string to remove the corrupted recycle bin folder. It worked. CCleaner is now running great! Thanks. Glad to hear it terico. Have a great weekend Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
