Moderators mta Posted October 27, 2013 Moderators Share Posted October 27, 2013 Admittedly I have only started using the portable build but have noticed that when you click on the Fragments or Size column headers to sort either ascending or descending, they do it opposite to what I'm used to. In the current Portable build (v2.16); ascending lists largest to smallest, descending lists smallest to largest. In my previous version of the full version, it was, and always has been, the other way around. So it's either a bug with the new version or has the portable build always done this? (or does Piriform use my location and have regionalised to Down Under accordingly ) Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Moderators mta Posted February 7, 2014 Author Moderators Share Posted February 7, 2014 woohoo - fixed in latest v2.17.898 release. it was only very minor - but bloody annoying. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Derek891 Posted February 7, 2014 Share Posted February 7, 2014 woohoo - fixed in latest v2.17.898 release. it was only very minor - but bloody annoying. Have you noticed that the water in the john is spinning in the opposite direction since it's been fixed? Start every day with a smile and get it over with. - W.C. Fields Link to comment Share on other sites More sharing options...
Alan_B Posted February 7, 2014 Share Posted February 7, 2014 Have you noticed that the water in the john is spinning in the opposite direction since it's been fixed? Personally I do not care which direction it spins in. I would however be rather peeved if effluent came up instead of going down. Link to comment Share on other sites More sharing options...
