Chupacabras Posted March 23, 2012 Share Posted March 23, 2012 Tryng to do full defrag but Defragger crashes immediately after analysis is complete. It's clean new installation of Defragger. debug file and windows crash report is attached. defraggler.exe.2_9_3912012-03-23_18-00.1.txt 59f6_appcompat.txt Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 23, 2012 Moderators Share Posted March 23, 2012 Thanks for the Logs. The developers read all threads, though rarely comment. Debug Logs are a good way to get it looked at, so they may ask for the .dmp file to be sent to them (was created when you run /debug, should be in the same folder). So hold on to that, incase they ask for it. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
