molasses Posted February 9, 2012 Share Posted February 9, 2012 Hello, Not a bug per-se, but just a quick courtesy note & a FYI concerning something I ran into with CCleaner and "Google Chrome Frame" I am trying out a program called Plex. Part of the installation recommends to install "Google Chrome Frame". http://www.plexapp.c...ownload-new.php This portion recommends the chrome frame install: For optimal performance and compatibility with Plex Media Manager, we recommend Google Chrome, Safari, FireFox, or IE9 with Google Chrome Frame. http://code.google.c...me/chromeframe/ When I ran CCleaner today I got a pop-up saying I needed to close Google Chrome. I did not have any web browsers open, so I looked at my running processes. I noticed ("chrome_frame_helper.exe" --startup") was running. After killing the process I was able to run CCleaner as normal. The "Chrome_Frame_Helper" is listed within a few start-up location within my system HKCU\Software\Microsoft\Windows\CurrentVersion\Run ChromeFrameHelper chrome_frame_helper.exe HKCU\SOFTWARE\Classes\Protocols\Handler gcf npchrome_frame.dll So this "chrome_frame_helper" is always going to run at startup, if I leave this helper installed As mentioned, I did not have any web browsers open. Thank you for having and maintaining such a fine set of tools. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 10, 2012 Moderators Share Posted February 10, 2012 Chrome frame tends to run in the background and is indeed a instance of chrome and thus is an open browser. Kill the process before cleaning chrome items via ccleaner ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
