Snapx Posted January 24, 2012 Share Posted January 24, 2012 Hi all, my suggestion is to add a MUI cache cleaner for windows 7 x64 ( cc cleaner not clear it ...and i don't kow why .... for now i use MUICacheView v1.01 to read and delete the MUI cache) and totally system event cleaner is very usefull! now i use a batch file, that i found on my internet search and works very well, here is the code @echo off FOR /F "tokens=1,2*" %%V IN ('bcdedit') DO SET adminTest=%%V IF (%adminTest%)==(Access) goto noAdmin for /F "tokens=*" %%G in ('wevtutil.exe el') DO (call :do_clear "%%G") echo. echo Event Logs have been cleared! ^<press any key^> goto theEnd :do_clear echo clearing %1 wevtutil.exe cl %1 goto :eof :noAdmin echo You must run this script as an Administrator! echo ^<press any key^> :theEnd pause>NUL I hope that it will be added in the future, bye. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted January 24, 2012 Moderators Share Posted January 24, 2012 Others will have a different point of view to me, but I don't like the idea of cleaning event logs as they are far too helpful for troubleshooting. They self-clean when they get to a certain size anyway. Welcome to the forum snapx. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
