Richard Matthis Posted November 21, 2011 Share Posted November 21, 2011 Greetings: We notice that CCleaner is not cleaning files out of a folder in the following location: C:/ProgramData/Microsoft/Search/Data/Applications/Windows/Projects/SystemIndex/Indexer/CiFiles Vista Administrators are not able do delete or alter the files in this folder. File types listed are as follows: CI File, DIR File, WID File, Microsoft Works Portfolio file, 000 File, 001 File (numbers increase based on date of the file), DIA File, etc. Another set of files that remain undetected by CCleaner are in a folder at the following location: C:/ProgramData/Microsoft/Search/Data/Applications/Windows/GatherLogs/SystemIndex File types are listed as CRWL File. Again, Vista Administrators cannot delete or alter these files. Picking these files up using Piriform Defraggler which let a user go the the folder of files it picks up in a routine. Microsoft and Big Brother are devising new ways to monitor and surveil all of us. Having software that will remove things is worth its weight in platinum. Thanks to the team at Piriform for its efforts to keep computers clean and safe! Richard Matthis Link to comment Share on other sites More sharing options...
nodles Posted November 21, 2011 Share Posted November 21, 2011 If the files are locked and can't be deleted by an admin, then CCleaner can't remove them either, I guess. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted November 21, 2011 Moderators Share Posted November 21, 2011 Hi Richard. As nodles says above re permissions to delete files, but if that wasn't the case, those two locations could be added to a CCleaner "exclusion" quite easily ... http://www.piriform....rs-for-cleaning Link to comment Share on other sites More sharing options...
nodles Posted November 21, 2011 Share Posted November 21, 2011 Yes, and you can also check custom Winapp2.ini-file. Link to comment Share on other sites More sharing options...
Super Fast Posted November 22, 2011 Share Posted November 22, 2011 I think you will find that usually, either Cedrick Collomb's Unlocker program will be able to remove it, or that you can remove the "System" attribute from the file(s) you wish to delete using Pete Romainges Attribute Changer program. Be sure that you do either from an Admin account with full access priviledges. Link to comment Share on other sites More sharing options...
