0gary0 Posted August 1, 2011 Share Posted August 1, 2011 Hey, I downloaded CCleaner a couple of months ago. Just downloaded and said scan. It messed up my Office 7 and some other stuff. When I asked people on this site, they said I should have "unchecked" the Office 7 program before running. I have no idea what I should check or let it clean. How do I set it up before I run it?? I am running windows vista, ie8. Thanks, 0gary0 Link to comment Share on other sites More sharing options...
Alan_B Posted August 1, 2011 Share Posted August 1, 2011 Hey, I downloaded CCleaner a couple of months ago. Just downloaded and said scan. Are you sure ? Nothing should be altered by a scan. When I asked people on this site, they said I should have "unchecked" the Office 7 program before running. Are you sure ? You only appear to have made one other post on the Bug Report forum to which no response appears. Are you getting advice elsewhere ? I have no idea what I should check or let it clean. How do I set it up before I run it?? I am running windows vista, ie8. I have only had grief with M.S.Office in the past, but for the beginner suggest DO NOT CLEAN THE REGISTRY Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 1, 2011 Share Posted August 1, 2011 We can't fully advise you on what to clean and what not to clean, you should check the documentation for that. I'd agree with Alan and say don't touch the Registry Cleaner. Also keep Wipe Free Space unchecked. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
