Pike Posted June 4, 2011 Share Posted June 4, 2011 CCleaner currently allows browser and Flash cookies to be excluded from cleaning, it would be great if it could do the same for Silverlight Application Storage "cookies". Thanks. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 10, 2011 Moderators Share Posted June 10, 2011 Silverlight cookies are cleaned by CCleaner only [Microsoft Silverlight] ID=2169 LangSecRef=3023 DetectFile=%LocalAppData%\Microsoft\Silverlight\is DetectFile2=%LocalLowAppData%\Microsoft\Silverlight\is Detect=HKLM\Software\Microsoft\Silverlight Default=True FileKey1=%LocalAppData%\Microsoft\Silverlight\is|*.*|RECURSE FileKey2=%LocalLowAppData%\Microsoft\Silverlight\is|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\Microsoft\Silverlight\is\*\|disabled.dat ExcludeKey2=FILE|%LocalLowAppData%\Microsoft\Silverlight\is\*\|disabled.dat You can add ones you don't want cleaned via options>exclude ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
