PQP Posted October 31, 2010 Share Posted October 31, 2010 I have several computers which I use. In order to be able to use CCleaner frequently, I had to work hard -- on just one computer -- in establishing a list of cookies to keep, so that following cleanup I won't have to introduce myself to my computer all over again. I'll now have to work just as hard, to establish the same list on the other computers (there are 5 total). I think that it would be greatly appreciated if there was a way to export the cookie list to a file, and to import such a list from a file. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 1, 2010 Moderators Share Posted November 1, 2010 Two simple ways to do this, use ccleaner portable or go to settings > Advaced and choose "save all settings to ini file" you can then copy the file created (in the ccleaner program folder though it may be in the %Appdata% folder for vista/win7) to each machine after setting each instance to save settings in ini file ( i.e hit that switch on each then overwrite the ccleaner.ini with the copied file) Honestly I'd suggest the first method . ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Mike_T Posted November 1, 2010 Share Posted November 1, 2010 The 'Cookies to Keep' only seems to work on IE. I wish I could select which cookies to keep on Firefox. I can get by on things like Remember Password but would still like to select which cookies I want to keep. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 2, 2010 Moderators Share Posted November 2, 2010 No ccokies to keep works explorer, firefox, opera, chrome and flash ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
