sieg131 Posted September 23, 2010 Share Posted September 23, 2010 what is work resolution for a monitor/graphics card? it allways seems to be a number of pixels lower on the vertical? can someone explain this to me? since there's no documentation on it. Link to comment Share on other sites More sharing options...
ishan_rulz Posted September 23, 2010 Share Posted September 23, 2010 For me, Current and Work Resolution are the same. Try changing your resolutions back and forth and see if it makes a difference. Simplicity is hard. Link to comment Share on other sites More sharing options...
sieg131 Posted September 23, 2010 Author Share Posted September 23, 2010 For me, Current and Work Resolution are the same. Try changing your resolutions back and forth and see if it makes a difference. i have and its normally 40 pixels lower (on my laptop i think it was 30?) changing resolution didn't change the difference in pixels (it was always 40 less) Link to comment Share on other sites More sharing options...
Andr? Queiroz Posted September 23, 2010 Share Posted September 23, 2010 The work resoluiton is the resoluiton you use (current resoluiton - taskbar = work resolution)... When you choose 'hide' at task bar propriets, the current resolution is the total work resoluiton... Bye! =D Link to comment Share on other sites More sharing options...
sieg131 Posted September 24, 2010 Author Share Posted September 24, 2010 The work resoluiton is the resoluiton you use (current resoluiton - taskbar = work resolution)... When you choose 'hide' at task bar propriets, the current resolution is the total work resoluiton... Bye! =D thank you ~! Link to comment Share on other sites More sharing options...
