Jim (BR) Posted August 29, 2010 Share Posted August 29, 2010 Bug observed on both Windows Xp x86 and Windows 7 x64. CCleaner v2.35.1219 (25 Aug 2010 release) I've noticed that when you keep on clicking (pressing the button multiple times in a row) on top of the buttons: "Run Cleaner" (Cleaner page) and "Fix Selected Issues" (Registry page) it will automatically bring that "division tab" abruptly to the right (it runs from left to the right side of the screen). I've also noticed that this bug does not occur when you click multiple times just at the lower portion of these buttons (half way down of each button). Link to comment Share on other sites More sharing options...
ishan_rulz Posted August 29, 2010 Share Posted August 29, 2010 It grays out when you click "Run CCleaner" So, technically it doesn't happen. Simplicity is hard. Link to comment Share on other sites More sharing options...
ident Posted August 29, 2010 Share Posted August 29, 2010 It grays out when you click "Run CCleaner" So, technically it doesn't happen. Actually he/she is correct (wXP) why a user would do this? God knows?????? bug to worry about no way No fate but what we make Link to comment Share on other sites More sharing options...
ishan_rulz Posted August 30, 2010 Share Posted August 30, 2010 Yeah, might be a bug but why would you do that?! Simplicity is hard. Link to comment Share on other sites More sharing options...
ishan_rulz Posted August 30, 2010 Share Posted August 30, 2010 Okay, edit: I observed it too. Sorry, misunderstood at first. Doesn't look like much of a problem But yes, ideally it shouldn't be happening. Simplicity is hard. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 30, 2010 Share Posted August 30, 2010 This actually occurs if you click anywhere in the results pane of the main cleaner several times. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Guest MrT Posted September 1, 2010 Share Posted September 1, 2010 Thanks. We'll look into this. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted September 1, 2010 Moderators Share Posted September 1, 2010 There must be something wrong with my CCleaner, I can't get that to happen. Link to comment Share on other sites More sharing options...
