CCleaner Community Forums
Sign in to follow this
bpell
Firefox icon problems
CCleaner does a great job except for Firefox. I am no longer able to see some animated gifs on web pages, or other gifs that are part of pages. The gifs just show up blank.
Similarly if I go to http://maps.google.com using firefox since running CCleaner the window that normally shows the maps is gray and blank. The words in the upper right hand corner "Map Satellite Hybrid" and "500 mi 500 km" appear in the lower left hand corner, as well as the google logo in the lower right. The maps DO NOT appear and if I type an address the popup is shown with words but all the images are blank.
Any ideas. I saw other posts indicating I should shut down firefox and run CCleaner twice or clear the cache but these efforts didn't work. I also tried to unistall firefox and reinstall it but that also didn't solve the problem.
Can you provide any help???
Thanks,
Brian
Share this post
Link to post
Thanks, but that didn't work. Can't seem to get this resolved. There are intermittent gif 's that don't show up. I have attached a picture. If I click on the image that is supposed to appear and click properties it tells me the image is missing?post-2838-1128183415_thumb.jpg
Share this post
Link to post
Are you using firefox preloader?
Can you elaborate? I checked all firefox settings and there is no setting for preloading. Still unable to view maps.google.com and several other images in firefox after running CCleaner. :(
Share this post
Link to post
Its not a default setting its a seperate program that can be downloaded. I figured you might be using it which would mean firefox would be open while running CCleaner.
Try this:
Go to tools>Options>Web features and make sure that the boxes that say enable java and java script are checked along with the box that says load images. Also make sure that the box that says "load images for originating site only" is unchecked.
Also what extensions do you have insatalled?
Share this post
Link to post
I'm having the same problem with Netscape 7.2. Netscape 8.0 seems to work okay, but it lacks the email support (i.e. Netscape Messenger) so it does not meet my needs. Any suggestions for fixing this problem within Netscape 7.2?
Share this post
Link to post
I'm having the same problem with Netscape 7.2 - I can no longer view animated GIFs. Any suggestions for fixing this?
Share this post
Link to post
Close the browsers completely.(look in task manager to make sure there is no processes running). Then run ccleaner twice.(just the cleaner)
Share this post
Link to post
22284[/snapback]
Thanks! It works fine now.
Share this post
Link to post
It only happens if you run ccleaner with the browser open. You really should dump netscape. If you need email and a browser get firefox and thunderbird. If you need them combined than get the mozilla suite(same as netscape but more secure due to updating.)
Anyway choose what you want here:
http://www.mozilla.org/
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
