brassman Posted January 16, 2010 Share Posted January 16, 2010 When the file list is filled after a scan and I scroll through the list using the scroll bar (by clicking the arrows or the page up/down area), one or both of the following happens: 1. extra horizontal lines are drawn across the text on each line (the extra lines look like the ones separating the rows of text) 2. no horizontal lines are drawn between the rows of text. When this problem appears, I can minimize the window and then restore it, and everything is drawn correctly. If I scroll through the list using the keyboard, I don't see such problems. Vertical lines seem to be drawn ok. I'm using version 1.34.460. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted January 16, 2010 Moderators Share Posted January 16, 2010 Which operating system are you using? Any skins, themes etc applied? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
brassman Posted January 17, 2010 Author Share Posted January 17, 2010 I'm using Windows XP with SP3. No skins or anything like that -- I'm using the app as provided in the download. I've downloaded the app more than once -- same problem occurs. One other thing -- if I scroll by clicking + dragging the scroll bar itself, the lines are drawn correctly. The problem only occurs when clicking the up/down arrows and the page up/down areas of the scroll bar. Link to comment Share on other sites More sharing options...
brassman Posted February 11, 2010 Author Share Posted February 11, 2010 sorry for the bump Just wondering if anyone else has seen this GUI issue, and if anyone at Piriform has reproduced it so it can be fixed (if it's a problem with the app and not my PC). Thx - Link to comment Share on other sites More sharing options...
