ccleaner09 Posted September 6, 2009 Share Posted September 6, 2009 ccleaner not cleaning system temporary files please fix it cause i delete the files by myself Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 6, 2009 Moderators Share Posted September 6, 2009 Which particular system temp files is it not cleaning? Which build and version of ccleaner are you using? Which operating system do you have? Are you a new user of ccleaner? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Glenn Posted September 7, 2009 Share Posted September 7, 2009 ccleaner not cleaning system temporary files please fix it cause i delete the files by myself Do you have Options > Advanced > 'Only delete files in Windows Temp folders older than 48 hours' selected? Link to comment Share on other sites More sharing options...
ccleaner09 Posted September 7, 2009 Author Share Posted September 7, 2009 tried what glen said didnt work Link to comment Share on other sites More sharing options...
ccleaner09 Posted September 7, 2009 Author Share Posted September 7, 2009 its not cleaning the temp in the computer just like you run stuff im using the latest version 2.23.999 im using xp im an old user Link to comment Share on other sites More sharing options...
Moderators DennisD Posted September 7, 2009 Moderators Share Posted September 7, 2009 From hazels post #2 above. Which particular system temp files is it not cleaning? You need to be more specific. Which files or the location of the aforementioned files. Link to comment Share on other sites More sharing options...
