Newbie User Posted July 6, 2009 Share Posted July 6, 2009 Hi, I am trying to use Recuva to recover files from a partially overwritten hard drive, using a USB thumb drive. I have added the file portable.dat as per the wiki. Using the wizard I have run the program and selected certain files to be recovered. When I click on the recover button, I am prompted to select a location for recovery, but no choices are given. I click on make new folder and the program does not respond. The only thing I can do is cancel and go back. What have I done wrong? Thanks! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 6, 2009 Moderators Share Posted July 6, 2009 Wiki advice old Just download the portable version http://www.recuva.com/download/builds Post back if this does not fix the issue ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Newbie User Posted July 7, 2009 Author Share Posted July 7, 2009 Nergal, Same error, any other suggestions? Link to comment Share on other sites More sharing options...
