Colin Posted August 17, 2005 Share Posted August 17, 2005 I have found if you setup the "CCleaner" to "Run Cleaner when the Computer Srtarts" and you go and check to see if the Windows "System Restore" has formed a later "Restor" point the System Restore program notifies you "System Restore cannot run untill you restart the computer. Please restart the Computer and then run System Restore again". Is it possible to have the CCleaner Setup programming to "Run Cleaner when Closing down"???? Love your program! Link to comment Share on other sites More sharing options...
englishmen Posted August 17, 2005 Share Posted August 17, 2005 Currently you can only run CCleaner when starting up which you can do via the CCleaner options. You can request to have it to run when you shut down tho by posting a suggestion here. Link to comment Share on other sites More sharing options...
Drew99GT Posted August 20, 2005 Share Posted August 20, 2005 Where in system restore can you view all the restore points? Link to comment Share on other sites More sharing options...
englishmen Posted August 20, 2005 Share Posted August 20, 2005 If you open system restore there will be 2 options "Create A System Restore Point" & "Restore My Computer To A Earlier Time" click on "Restore My Computer To A Earlier Time" and a calender view with all your previous restore points will appear click the one you wish to restore. Link to comment Share on other sites More sharing options...
Drew99GT Posted August 20, 2005 Share Posted August 20, 2005 Thanks Englishman Link to comment Share on other sites More sharing options...
