Garetiem Posted March 1, 2009 Share Posted March 1, 2009 every time i use defraggler my computer comes extremly slow, it's the same no matter what computer i do it on, and even if it's done on a clear windows install all systems are Windows XP SP3, and my file system is NTFS, i've tried both on SATA and IDE harddrives... surely defraggler is the problem as the computers doesn't have any loading problem before using the program, aswell after a new windows install Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 1, 2009 Moderators Share Posted March 1, 2009 Is that during the active defrag process, or after the defrag has completed and you've closed Defraggler? Link to comment Share on other sites More sharing options...
Garetiem Posted March 1, 2009 Author Share Posted March 1, 2009 Is that during the active defrag process, or after the defrag has completed and you've closed Defraggler? after, i'm never using my computer while running the defrag Link to comment Share on other sites More sharing options...
Garetiem Posted March 3, 2009 Author Share Posted March 3, 2009 i would really like some feedback on this, as the problem keeps appearing nomatter what computer i use defraggler on Link to comment Share on other sites More sharing options...
