Cel Posted October 23, 2008 Share Posted October 23, 2008 XP Pro SP3 CCleaner 2.12.660 version I recently learned how to use the macromedia flash panel settings. http://www.macromedia.com/support/document...r07.html#117717 Using FireFox 2.0.17 as my browser, I set it up for best security settings. I then used CCleaner and found it removed the file on my computer where the settings are stored. Is there something I have set wrong in CCleaner? Under windows tab I have everything checked except there are no checks in advanced section. Thanks Take Care Celeste PS Sorry I posted this in wrong area and can't find out how to delete the post so I will leave it here. I meant to post in open discussion area. I don't think this is a bug as much as I as the operator of CCleaner may be doing something wrong. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 23, 2008 Moderators Share Posted October 23, 2008 Try under the CCleaner application tab, unticking adobe flash player (macromedia) Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Cel Posted October 23, 2008 Author Share Posted October 23, 2008 Try under the CCleaner application tab, unticking adobe flash player (macromedia) Yeppers that is it. Thank you Take Care Celeste Link to comment Share on other sites More sharing options...
