abu aufa Posted September 19, 2008 Share Posted September 19, 2008 Hello.. I got some problem with my OS Yesterday, I successfully upgrade to XP SP3(no big deal).Now, windows always notify me to install net.1.1 SP1.I tried to install it but failed and failed again. How to solve this problem ? is it important to install it ? OS : XP Pro SP3 NET.FRAMEWORK 1.0,2.0,3.0 & 3.5 INSTALLED AVIRA free Thank for the support Link to comment Share on other sites More sharing options...
davey Posted September 19, 2008 Share Posted September 19, 2008 Hello.. I got some problem with my OS Yesterday, I successfully upgrade to XP SP3(no big deal).Now, windows always notify me to install net.1.1 SP1.I tried to install it but failed and failed again. How to solve this problem ? is it important to install it ? OS : XP Pro SP3 NET.FRAMEWORK 1.0,2.0,3.0 & 3.5 INSTALLED AVIRA free Thank for the support Hi Abu, Nice seeing you again. This guy has the "magic" when it comes to .NET framework. I have used his tool a few times. Bookmark and save it to Favorites, this time. http://blogs.msdn.com/astebner/archive/200.../08/406671.aspx And this reminder thread. http://forum.piriform.com/index.php?s=&...st&p=107619 You may need this thread also. This will be part of your fix. Yes each .Net Framework version may be needed at different times. http://forum.piriform.com/index.php?s=&...st&p=102524 I find that I have enough problems in life without creating more for myself. This includes "cleaning" the Registry and also trying to save a few bytes by removing parts of my Windows OS. Life can be more fun if we just keep it simple! Good luck and see you later, davey BTW, have some fun with people you enjoy ! Link to comment Share on other sites More sharing options...
abu aufa Posted September 19, 2008 Author Share Posted September 19, 2008 Hi Abu,Nice seeing you again. This guy has the "magic" when it comes to .NET framework. I have used his tool a few times. Bookmark and save it to Favorites, this time. http://blogs.msdn.com/astebner/archive/200.../08/406671.aspx And this reminder thread. http://forum.piriform.com/index.php?s=&...st&p=107619 You may need this thread also. This will be part of your fix. Yes each .Net Framework version may be needed at different times. http://forum.piriform.com/index.php?s=&...st&p=102524 I find that I have enough problems in life without creating more for myself. This includes "cleaning" the Registry and also trying to save a few bytes by removing parts of my Windows OS. Life can be more fun if we just keep it simple! Good luck and see you later, davey BTW, have some fun with people you enjoy ! Thank for quick answer,Davey I used the cleanup tool to remove net 1.1,2.0,3.0 & 3.5.Now what ? Reinstall them ? or leave it alone and just install the latest 3.5 SP1 ? will it affected my OS? Thanks a lot Link to comment Share on other sites More sharing options...
davey Posted September 19, 2008 Share Posted September 19, 2008 (edited) Thank for quick answer,Davey I used the cleanup tool to remove net 1.1,2.0,3.0 & 3.5.Now what ? Reinstall them ? or leave it alone and just install the latest 3.5 SP1 ? will it affected my OS? Thanks a lot I would install them all and eliminate any future problems that way. davey P.S. I have them all installed and never encountered any problems. It is mysterious sometimes . Whenever I have my tools in the trunk of my car, I never have any breakdowns. If I don't have my tools, Bang! something breaks and there I am with no tools. I would rather have my tools with me and not need them then the other way around. Sure makes the traveling a lot easier. Edited September 19, 2008 by davey Link to comment Share on other sites More sharing options...
YoKenny Posted September 19, 2008 Share Posted September 19, 2008 It is mysterious sometimes . Whenever I have my tools in the trunk of my car, I never have any breakdowns. If I don't have my tools, Bang! something breaks and there I am with no tools. Murphy's Law holds true all the time:http://forum.piriform.com/index.php?showtopic=16775 I have all of the .NET framework installed with all of their updates. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to comment Share on other sites More sharing options...
Moderators DennisD Posted September 19, 2008 Moderators Share Posted September 19, 2008 I would install them all and eliminate any future problems that way. davey I would agree with davey and Ken, although I don't have 3.0 or 3.5 installed myself, yet. If you're missing the earlier ones, you will probably at some time hit backwards compatability problems with software written on the earlier platforms. Link to comment Share on other sites More sharing options...
