Artliner Posted September 21, 2007 Share Posted September 21, 2007 I want th epossibility to reset the settings in every tab to the original value?s. Today i have some problems because i changed to much and i don?t know what are default settings and what did i marked. Link to comment Share on other sites More sharing options...
JDPower Posted September 25, 2007 Share Posted September 25, 2007 I want th epossibility to reset the settings in every tab to the original value?s.Today i have some problems because i changed to much and i don?t know what are default settings and what did i marked. Go into CCleaners program folder (C:\Program Files\CCleaner) and delete the 'CCleaner configuration settings' file (this will remove ALL your settings) Link to comment Share on other sites More sharing options...
