Drummer17 Posted September 22, 2011 Share Posted September 22, 2011 Hello, I try to recover files from an external hard disk (NTFS, 1.5 TB) using Recuva. The search process (using deep scan) lasts very long an d at the end I do not get a result but a message, that there is not enough memory. What can I do to obtain a result? Michael Link to comment Share on other sites More sharing options...
Moderators Augeas Posted September 22, 2011 Moderators Share Posted September 22, 2011 How much memory do you have? I can only suggest the obvious: close all other applications so that memory use is minimal and try again. You could disconnect from the internet and close your a/v as well. Scanning a 1.5 tb disk will take a very long time, and presumably a lot of memory to manipulate Recuva's temp file. if you have progressed to stage 2 you can cancel it with no ill effect that I can detect. This might save a few zillion bytes. Link to comment Share on other sites More sharing options...
redhawk Posted September 22, 2011 Share Posted September 22, 2011 Is there a reason why you're performing Deep Scan instead of performing a regular scan?? How did you lose your files i.e. deleted, vanished or corrupted partition table?? Richard S. Link to comment Share on other sites More sharing options...
Drummer17 Posted September 22, 2011 Author Share Posted September 22, 2011 Hello, I am performing deep scan, because regular scan did not succeed finding my files.Deep scan find my files and let me restore them. I tried this by interrupting deep scan and using the given reults until I stopped. However, with this procedure I do net get all files. I am using a PC with windows 7 and 2 GB RAM. The scan time is not the problem, I ran it during the night, but I need reults. I will try with a macine having more RAM. Michael Link to comment Share on other sites More sharing options...
