metalj Posted September 14, 2010 Share Posted September 14, 2010 This is what i did: 1. I analyze one of my drives 2. Then I go to the "File list" tab 3. I check the box at the very top (to select all) 4. Then I press "Defrag Checked" Everything was nicely defragged, Drive tab says 0 Fragmented Files, 0 Total, 0% Everything in the "File list" tab is in one fragment. But the drive map is the same as after the first analysis. I can even click the red blocks, and it shows fragmented files that were actually defragged. If I reanalyze, the drive map updates as it should be. (note: the drive map does show activity during defrag) I was able to reproduce this twice with two of my drives. I did not attached any screenshots because this is very easy to reproduce but if you need them, just ask (or anything else I can help with ). I am using Win XP SP3, and Defraggler 1.21 Edit: quick edit Piriform Software User Guides Link to comment Share on other sites More sharing options...
metalj Posted October 29, 2010 Author Share Posted October 29, 2010 I was able to reproduce this with Defraggler v2 Are you guys going to fix this in v1, v2? Piriform Software User Guides Link to comment Share on other sites More sharing options...
mr don Posted November 6, 2010 Share Posted November 6, 2010 + 1 I can verify this exists in Defraggler 2 Beta under XP. - Open Defraggler & click Analyze - Click a red block of fragmented data - Click select all & hit defrag Drive map fails to update to reflect that the files have just been defragged. In fact, you can select the same red data block over, & over, & over to be "defragged" & it still appears to be "fragmented" by the map, even though the defrag sessions now take nearly no time at all due to them already being defragged. Re-Analyzing seems to update the map, but should this be necessary? Definitely needs fixing, please. Link to comment Share on other sites More sharing options...
Guest MrRon Posted November 8, 2010 Share Posted November 8, 2010 Thanks, we'll have a look at this Link to comment Share on other sites More sharing options...
metalj Posted November 10, 2010 Author Share Posted November 10, 2010 Not fixed in v2.00.230 :( Piriform Software User Guides Link to comment Share on other sites More sharing options...
Gingko Posted November 19, 2010 Share Posted November 19, 2010 I want to confirm this bug too (effectively not fixed in 2.00). This is a regression lasting for near that one year now, probably starting from 1.16 or 1.17, I don't remember exactly. Quite painful. Gingko Link to comment Share on other sites More sharing options...
metalj Posted January 10, 2011 Author Share Posted January 10, 2011 It's still not fixed in v2.01 Are you guys going to fix this bug? Piriform Software User Guides Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 10, 2011 Moderators Share Posted January 10, 2011 Not all bugs are fixed easily. If the developers have said they are looking on it, they are. I understand wanting an update on the progress of a bug fix but please don't be rude toward the developers who are providing you their hard work for free. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
metalj Posted January 11, 2011 Author Share Posted January 11, 2011 Woah, dude, slow down. I wasn't trying to be rude. I just wanted to bump this topic because it disappeared. Piriform Software User Guides Link to comment Share on other sites More sharing options...
metalj Posted February 2, 2011 Author Share Posted February 2, 2011 Ok, I tried v2.02 and its still not fixed. I did notice that empty blocks do update after a new file is placed on them. The rest of the blocks don't change, as I reported previously. But isn't Defraggler supposed to update the drive map as it defrags? (You know, every block, individually, after Defraggler finishes working with it.) Piriform Software User Guides Link to comment Share on other sites More sharing options...
romanoff Posted February 2, 2011 Share Posted February 2, 2011 Hi, Thank you for reporting the issue. It has been added to our development plans. Best regards Romanoff Link to comment Share on other sites More sharing options...
metalj Posted March 15, 2011 Author Share Posted March 15, 2011 It seems to be fixed in v2.03 Thanks. I'll report anything else I find. Piriform Software User Guides Link to comment Share on other sites More sharing options...
