JeremyWW Posted October 5, 2009 Share Posted October 5, 2009 CCleaner 2.24.1010 / Windows 7 Build 7100 (Official RC) / Firefox 3.53 / Java 1.6.0_16 Simply: the Sun Java cache is not cleaned. Tried a number of times with all apps closed, then check in the Java Control Panel - cache files are still there. Updating this in the hope that someone else will please test and confirm. Now running clean (formatted HD) install of Windows 7 Ultimate. CCleaner still does not clean the Java cache after running Java applets in Firefox on various sites. Why doesn't this work? Link to comment Share on other sites More sharing options...
ePost Posted October 5, 2009 Share Posted October 5, 2009 Is the related to FireFox or is it the same for Java cache temp files that came via IE? Free online Windows Live OneCare safety scanner here for XP - here for Vista/Windows 7 Link to comment Share on other sites More sharing options...
JeremyWW Posted October 5, 2009 Author Share Posted October 5, 2009 Is the related to FireFox or is it the same for Java cache temp files that came via IE? Just tested it - it's the same for both IE and FF... Link to comment Share on other sites More sharing options...
ePost Posted October 5, 2009 Share Posted October 5, 2009 Would anyone happen to know if the cleaners PureRa and JavaRa from RaProducts support Windows 7? They are known to be fairly harmless and to do a fine job but I would not dare to recommend them without knowing if they can run on a Windows 7 OS. Free online Windows Live OneCare safety scanner here for XP - here for Vista/Windows 7 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 6, 2009 Moderators Share Posted October 6, 2009 On it's web page for JavaRa it says Currently, JavaRa supports Windows 9x, 2k, XP, and Vista without UAC. So I suspect not. http://raproducts.org/javara.html I'm sure they will be working on it. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
ePost Posted October 6, 2009 Share Posted October 6, 2009 Thanks, hazelnut. I did actually go to RaProduct's site but I did not find the system requirements. I must have been sleepwalking. The information is listed loud and clearly... Free online Windows Live OneCare safety scanner here for XP - here for Vista/Windows 7 Link to comment Share on other sites More sharing options...
JeremyWW Posted November 4, 2009 Author Share Posted November 4, 2009 CCleaner 2.24.1010 / Windows 7 Build 7100 (Official RC) / Firefox 3.53 / Java 1.6.0_16 Simply: the Sun Java cache is not cleaned. Tried a number of times with all apps closed, then check in the Java Control Panel - cache files are still there. Updating this in the hope that someone else will please test and confirm. Now running clean (formatted HD) install of Windows 7 Ultimate. CCleaner still does not clean the Java cache after running Java applets in Firefox on various sites. Why doesn't this work? Link to comment Share on other sites More sharing options...
Deke40 Posted November 5, 2009 Share Posted November 5, 2009 I was having the same problem in Vista Home Premium. I just the added the path to my "Include" section of CC and it takes care of them that way. C:\Users\Deke\AppData\LocalLow\Sun\Java\Deployment\cache\6.0 Take Care Deke40 Link to comment Share on other sites More sharing options...
