dmurphy Posted February 24, 2007 Share Posted February 24, 2007 My monitor, although it says it will in the manual, will not display a resolution of 1280x1024. I have a crappy fx5500 but it worked fine with a different monitor of the same brand, both using the dvi connection. I've tried re-installing the graphics card drivers but still nothing. Any help would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
New_Age Posted March 7, 2007 Share Posted March 7, 2007 My monitor, although it says it will in the manual, will not display a resolution of 1280x1024. I have a crappy fx5500 but it worked fine with a different monitor of the same brand, both using the dvi connection. I've tried re-installing the graphics card drivers but still nothing. Any help would be appreciated. Thanks.What brand of Monitor and how old is it? CRT or LCD? What OS you have? Windows 98SE, 2000 Professional, Xp Professional or Home? Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
