Widkidone Posted August 2, 2006 Share Posted August 2, 2006 Has anyone heard of this? Here is the website How would this be compare to CCleaner? Link to comment Share on other sites More sharing options...
Moderators TwistedMetal Posted August 2, 2006 Moderators Share Posted August 2, 2006 Since you asked, I downloaded it, and installed it on my test PC. #1. It says FREE, but in the help file it says it costs. The program has a time limit on it. #2. I didn't like the GUI, sorta complex, and childish background images. #3. It doesn't support as many programs as CCleaner does. #4. It has a search for junk files. (Scans your hard drive for temp files, backups, and so on...) I don't like it when programs do that, it's just asking for trouble. #5. Doesn't have that winapp2.ini support like CCleaner does. Has to be hard coded in the program (less likely on updates). #6. ADVANCED MODE: You can choose the items you wish to cleanup. An automatic backup of your registry is created each time you run Zappit. Using this mode you have access to a full range of cleanup options. Advanced Mode allows you to remove a wider range of files, folders and settings than Safe Mode. Use Caution! Zappit is a powerful cleanup tool. Files, Folders and Registry items removed with Zappit cannot be recovered. To put it shortly... It doesn't even hold a candle to CCleaner. Your Friendly Neighborhood Piriform Forum Moderator Quick Links: CCleaner Products | CCleaner Documentation | Knowledge Center | Downloads | Lost License Key Link to comment Share on other sites More sharing options...
