Adel Posted June 11, 2006 Share Posted June 11, 2006 After long hesitations, i decided to download the latest version of cc 1.30.3. Anyway, when i do a scan for issues, I get the option to fix the issues. With this version It doesn't fix anything. I did many attempts to fix the issues one by one, & when it's all done & fixed, I do another scan for issues just to make sure there aren't any left. To my surprise the same issues keep coming up. I did this many times to no avail. I never had this problem w/ older versionss. Any help shedinh light on this would be appreciated. Thank you. Link to comment Share on other sites More sharing options...
krit86lr Posted June 11, 2006 Share Posted June 11, 2006 Give this a shot and let us know if it works. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
Adel Posted June 11, 2006 Author Share Posted June 11, 2006 Thx for replying, I downloaded dj's dial a fix, followed the steps until the end & then run a cc issues scan. I did find issues that need fixing( this time more issues than before . ) Then I fixed the issues & run another scan. result? No issues were found this time & I am very happy i might add. Thank you for your help. DJ, that's one fine piece pf software you got there, thank you. Link to comment Share on other sites More sharing options...
