Tuinlaaf 0 Posted February 1, 2019 Share Posted February 1, 2019 My CPU temperature does no longer show up after I upgraded to Win 10 1809. Also there is a weird chipset thing going on. I'm sure it wasn't there before. Link to post Share on other sites
Moderators mta 0 Posted February 2, 2019 Moderators Share Posted February 2, 2019 check if there is a BIOS update for that motherboard. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to post Share on other sites
ZZWolf47 0 Posted February 13, 2019 Share Posted February 13, 2019 I have the same issues... the bios still reports the temp and so do other programs. Link to post Share on other sites
ZZWolf47 0 Posted February 20, 2019 Share Posted February 20, 2019 It is not a bios issue. windows did a have a update, and after that, the program does not work like it did. Something in the program needs to be updated and a update needs to be worked on asap. Link to post Share on other sites
GregJecht 0 Posted March 28, 2019 Share Posted March 28, 2019 Since this morning I'm having the same problem. Link to post Share on other sites
Sammy22 0 Posted July 5, 2019 Share Posted July 5, 2019 (edited) Just like the other reports in this thread I have the same problem. I imagine a number of other Speccy Users also have this issue. I will create a bug report to go with this post. When you are watching overall PC temperatures then the CPU and Motherboard temps are quite important measurements. To help with more info I installed Speedfan which can read PC temps and it showed my CPU as 128 degC (un-rounded value is 127.5) which I did not believe so starting the PC up new on the next day I checked Speedfan and the CPU temp was still 128 degC. This seems to indicate a reading problem. The same reading problem may be true for Speccy. As other people have this same problem with Speccy and CPU + Motherboard temps then it is not likely to be a hardware issue in my PC but more likely as previously surmised it has come about from a Windows update. It would be really nice if this were fixed in Speccy but maybe it works fine in most cases and these are just isolated incidents. I use Speccy v1.32.740 (64 bit). Please let me know if this version works fine for you. Thanks. Updated: I searched for another product to read CPU temperatures just for my piece of mind that there was no hardware issue and was happy to see there was no hardware problem. Image added showing results from "Real Temp". Edited July 5, 2019 by Sammy22 Added new image showing CPU Temps Link to post Share on other sites
alberto29 0 Posted October 22, 2019 Share Posted October 22, 2019 (edited) Ryzen-2600, мать Gigabyte B450 AORUS, температура процессора показывает 80-90 ... градусов! Не в биосе, не в райзен мастере, не в автобернер MSI нет таких температур! Экстрим тоже нормальная температура 34-36 градусов. на другой мамке x 470 тоже гиговской точно так же. видеокарта с 6 гб памяти показывает 2047 мб! удруга на r9-280x с 3 гб показывает именно 3 гб! стресс тест айда прошел максимум 59 градусов! Edited October 22, 2019 by alberto29 добавление файлов Link to post Share on other sites
Phlonk 0 Posted December 10, 2019 Share Posted December 10, 2019 I have the same issue with no CPU temperature showing on Speccy now that I updated my system. I am using the Gigabyte x570 Aorus Elite motherboard with AMD 3600x CPU. I have updated to the latest full release bios F10 and still nothing showing only for the CPU all the other temps seem to show. Is there going to be an update coming out to address this issue? Thanks for your time. Link to post Share on other sites
pkmaniac96 0 Posted December 10, 2019 Share Posted December 10, 2019 I updated to latest windows 10 version 1909 and i have the same issue ,temps of cpu,ram and motherboard are not showing Link to post Share on other sites
cvrtr 0 Posted May 13, 2020 Share Posted May 13, 2020 Though I'm quite late to the party, I've recently found myself experiencing the same issue, with no clue whatsoever about what caused it. But I managed to fix it by going to Speccy's installation location and enabled the "Run this program as an Administrator" option from the Speccy executable. Link to post Share on other sites
Phidaissi 0 Posted June 30, 2020 Share Posted June 30, 2020 (edited) Came here to note this is an issue for me too. Just upgraded PC and did a fresh install, and: can't see CPU temp no RAM details incorrect memory reading on video card (it's 6GB not 2GB) I'm on a Ryzen 5 3600 with a GTX 1660 super, so this seems to be a problem for all newer hardware. Edited June 30, 2020 by Phidaissi Added screenshot Link to post Share on other sites
LegalMinn 0 Posted March 19 Share Posted March 19 Uninstalled and reinstalled, and the temps were back. Link to post Share on other sites
