Judith C Posted September 16, 2018 Share Posted September 16, 2018 After working with the Amazon techs for quite a while to get the CC Cleaner app to work on my Kindle Fire 10HD, they concluded that it is a developers problem. The program will download, install and analyze but the "clean" button is disabled. Are there any solutions or work arounds to get the program to work on a Kindle Fire? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 16, 2018 Moderators Share Posted September 16, 2018 See my reply to your other post. Double post closed ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
