New_Age Posted May 19, 2006 Share Posted May 19, 2006 Hi, I need to know where to find Free software that will let me use all the textures and visuals such as This! Note: I don't want a program that will mess up my system either Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
Moderators rridgely Posted May 20, 2006 Moderators Share Posted May 20, 2006 Well first you need to patch uxtheme.dll. Its fairly simple and you can find good instruction here: http://www.neowin.net/forum/index.php?showtopic=140707 Then download the file and unzip it. Put the msstyle file in C:/Windows/Resources/Themes. The other contents of the zip file is the background(.jpg) and then the program that will turn your taskbar transparent. That one I have never tried. Hope that helped. Link to comment Share on other sites More sharing options...
