Lotem Posted October 9, 2016 Share Posted October 9, 2016 It seems that formation works good? It also deleted everything? Because now i am using recuva deep scan and it found 23 files only that it is recovering. When to use recuva? And diskfragmentation? And what is folder structure in the options? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 9, 2016 Moderators Share Posted October 9, 2016 Locked This is a official company website and thus side-by-side comparison with competition is not allowed. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
