Winapp2.ini Posted March 12, 2012 Share Posted March 12, 2012 I noticed two small issues (one of which may not be ccleaner's fault) recently: Running the automated "Close thunderbird to clean cache" while Thunderbird is minimized to the System Tray fails to actually close Thunderbird. While the dialog to close a browser/email client is open, CCleaner does not present itself in the Windows Aero alt tab (did not check Win Tab or Basic Alt Tab) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 28, 2012 Author Share Posted March 28, 2012 I'm glad to report that in V3.17, CCleaner will force close the application if it cannot close it normally. The other issue, however, remains unresolved. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Guest MrT Posted March 28, 2012 Share Posted March 28, 2012 Thanks, we'll look into the tab issue. Link to comment Share on other sites More sharing options...
